Nexxuos monsta rad
28 Nov 2004
Can i use the bleed port on the nexxos monsta rad for a barb at the other end.
want a barb at the left and right of the radiator. thanks in response ;)
No because if you used the bleed port at the end of the radiator, coolant won't flow around the entire radiator; it'll only go down one side.
You're looking for a cross-flow radiator?
