NexXxos XP Bracket
24 Mar 2006
I did have a socket 939 motherboard and decided to go watercooling. I brought a NexXxos XP CPU waterblock. However, after about 2 weeks of cooling with this block my Mobo, RAM and HDD all went kaputt. So i decided to upgrade to C2D. So obviously I need a cpu waterblock which will fit a 775 socket.
Now, the NexXos XP block for 775 is exactly the same as for 939 except it has a different bracket. Is there any way of getting this bracket without having to spend £30?
Thanks
Dunno, I had to buy a new block tbh.
I also used a thermaltake H-Bracket for a while which did the trick nicely. If you can get a 2nd hand big typhoon for a tenner it might be worth it for you.
