- 15 Jul 2004
- Ynysybwl
I recently bought a new motherboard, a DFI with an NF4 chipset, popped it in, installed windows through my pioneer DVR-111DSV, once that was up and running, popped a disc in to install sp 2, and nothing. So, I used my other drive, a CD drive, to install sp2 and the rest of my stuff, but the DVD drive won't recognise any disc, you can stick a disc in and it'll pick up that there's a disc in there, but you won't be able to read the disc, I know it works as it was used before I upgraded, and I installed windows off it, I've tried upgrading the firmware, changing IDE drivers from the nforce to the standard drivers (though when windows first loads it's using standard IDE drivers and doesn't work anyway). The only way I've been able to get discs to read in the dvd drive is after updating the drivers through the device manager, it will read discs, but quite slowly, you can get the data off the disc, but it won't play a game or a dvd. And then when you restart it'll go back to not working. Anyone have any ideas?
Cheers.
Cheers.
