Yea easy it allows up to 180mm height d15 is 165mm with fans should still fit even if you have a 140mm over the ram.
It's right there on the define s spec page on their site.
Thanks. I will have a 140 over the ram. So will I have to move the fan up a bit to clear the ram and therefore increase the height a tad? Hopefully it's all fine..
nah should just fit even with the fan raised slightly above and not touching the ram
I have a noctua d14 and my case cooler height restriction is 163mm I have 2x 140's on the heatsink and one above the ram and it all fits so...
