NH U12P, will it fit?
27 May 2009
Can you tell me if this CPU cooler fits in the coolermaster cosmos s?
I am going to fit this cooler after unsuccessful temps with watercooling.
What temps will this cooler give to a corei7 DO steeping OC'd to 3.2GHz.
Thanks.
It will fit fine. Your chip should be good for ~4ghz, running it at 3.2 is extremely conservative!
Yeah, it'll be great - runnning mine at 4.1GHz getting temps of about 41/43 idle and 78/80 load under prime blend, and that's with the warmer weather we're getting down here in Cornwall at the mo! :D
