nHancer wont load (nicks FSX Tune out of date)
11 Oct 2010
Im trying to follow NickN's guide to tweaking FSX and he suggest using nHancer but it wont load - ive read that its no longer updated by creator and it wont load due to driver version
can anyone help me get this loaded?
thanks
Try going into the xml config file for the exe and set the check for version value to 0. See if that helps but remember nhancer was only designed to work for nVidia driver before the 257.xx series, from what I understand about it.
That's really all I can help you with regarding Nvidia cards, I have not used one in a while and as you will see from my sig i'm using a ati/amd 5870 for FSX. Have been thinking about getting a GTX 580 but really can't see the benefits right now for a GPU upgrade.. Will wait till intel brings out the new CPU's (2011) with more cores and will do a full system update then and will see if Nvidia has the better card then for FSX.
This is what most people using Nvidia GPU and FSX are using now.
NVIDIA Inspector 1.95
http://blog.orbmu2k.de/tools/nvidia-inspector-tool
This may explain it better for you, regarding NVIDIA Inspector and FSX settings.
http://www.simforums.com/forums/nhancer-settings-for-new-drivers-updated-v1932_topic36586.html
