How do you go about combining two or more NICs under XP?
I'd like to combine my onboard NIC with my PCI NIC, at the moment I have both connected to my switch and they both have separate IPs, but whenever I'm transferring stuff across my network it only uses the onboard NIC rather than balancing the load between the 2 cards.
I've spent a lot of time searching and although it seems doable under win 2k and of course *nix based systems I can't find a way to do it under XP.
Any ideas?
Any ideas?
