Nice flash game - drawing shapes
I can't actually do 5.
I can make a swinging arm, but it doesn't give it enough power to get up the steps, even when I stick triangular ramps against them...
HELP.
Is the pin thing working for everybody? I hold "S" then click but nothing happens
EDIT: Didn't realise you had to pin shapes to shapes
I used shapes to knock the blue rectangle off the ledge then made a ramp up to the upper flag. Rolled the ball to the other one :D
Woohoo....done level 10 \o/
I worked out what you said and built a big swinging arm to whack the ball to the top level using a ramp.......yey.
Level 12 now....
make that 13 :D:D
Addicted now :(
Level 14.
They get easier :/
15.
That'll do for tonight... upto level 16.
