- 22 Mar 2009
I had managed to fitted a new Prolimatech Megahalems Rev B CPU Cooler with a new Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan (just a single fan) and replaced all my antec 1200 case with 5 fans of these Fractal Design 120mm Silent Cooling Fan (3 at the front and 2 at the rear back)
Done prime95 with small FFTs stress and done linx stress all passed. The temperature was even much better than last time was 76C max, but this time, just 72C max with my room temperature of 23C. I wouldn't worry about the scythe kaze jyuni 1900RPM fan was too loud, because I set the bios fan as voltage on the cpu to control the fan as it will reach high speed fan during overclocked, but remain quiet when it reached idle speed (down to around mid 1350rpm to 1500rpm)
Here is the result of linx stress:
Here is the result of prime95 small ffts stress:
Overall, the Prolimatech Megahalems Rev B CPU Cooler is 4 degrees less than my old Noctua NH-U12P SE2 Dual Fan Quiet CPU Cooler with a push pull fans of 2 x Noctua NF-P12.
What you all think of this ?
