Would de ionised water cause nickle plating to bubble and flake off?
My cpu block is flaking so I have sent it for rma, they are now asking if I used Distilled.
I can’t remember if I used de ionised with concentrate or pre mix, both mayhems x1. I’ll have to dig out coolant box and see what’s in there.
surly it don’t matter what water I use as x1 has inhibitors and says on the bottle to mix with DI water and the water block instructions says not to use pure distilled. I know ek had issues with plating In the past but they now use a different plating process that is more resistant.
