NickXX - or anyone with BMW EPC/TIS
Permabanned
17 Jan 2006
Haskins
hi
Could you let me know the part numbers for front discs and pads for a 320d (E46) from the EPC discs!?
I dont have a chassis number, so you'll have to search if you dont mind
Thanks
Hi mate,
The Brake Disc, Ventilated is '34 11 1 164 539'.
The Brake pads, Asbestos-Free are '34 11 6 761 244'
This is for a 2002 e46 320d Saloon
Hope this helps :)
RealOEM
Think of a very large number, then multiply that number by an even larger number. Thats how many parts are listed and catalogued with diagrams on this site. It's nuts.
and unfortunately the parts on realOEM.com, being American, vary drastically from the UK spec part numbers (although i'm sure the parts are actually the same!)
EDIT: - To be fair, that site has actually now got very good. Part numbers are almost spot on!
