I cannot get a happy install on my I7
The basic specs are:-
Saphire PureBlack Motherboard
I7-970 6 core @ stock
6x4GB GSKILL
Windows 8.1 but currently back onto Windows 7 - 64Bit of course
SoundBlaster 3D Recon
Now, it happened with 8.1 and at the time I did use a downloaded ISO to play with, and so I asumed it was the ISO and so I installed off my proper disc btu that made no difference. After some messing about, I actually gave up and went back to Win7 just in case there was some issue with Windows 8, but Windows 7 did the same thing.
I did go even further back to XP64 and that seems to be fine, but that just erked me and so I am back onto Windows 7 right now.
Now, whats happening, is that some apps, and quite a few of them actually, take absolutely ages to start up.
Big ones are Nero and UltraISO. These two I use a fair bit, and they take so long to start up that I did in fact think they simply would never start. I went into the TaskManager and saw half a dozen of them and I removed them all and double clicked again, but it still didnt start up. I forgot about it, got on with looking through my system tools for another burner and ISO app, and some 15 or 20 minutes later, UltraISO started up.
15 or 20 minutes later????? Come on!
I shutdown and restarted the PC and after a wait to make sure everythign was fully in, I double clicked on NERO and timed it...12 minutes to start up
Did the same with ultraISO and timed that and that took 14 Minutes.
I have noticed this happen on a few apps, and I was wondering why the hell this could happen?
The only thing Ican think of, is the RAM, and so I ahve done a number of things such as try less ram, swapping slots, and even trying different makes of RAM, but nothign seems to make any difference?
Any clues as to what I can try?
6x4GB GSKILL
