Hi, Ive just got myself a Sony A65 with stock lens, could anyone point me in the direction on what settings to use for night sky and star photos, im very new to this but can find my way around the camera setting just about
Thanks ..
adbp1 said:Not that I have that much experience but I asked same question 6 months ago, and was given these sorts of settings, small fstop like 2.8 with relative high iso like 1600 or above and try not to go above 30 seconds and the stars start to move and cause lines
As I found a lot of it is in good quality lens I ended buying a good wide angle
Not sure if your area is the same but around here a lot of street lighting is switched off after a certain time to save electrickery. If that's done in your area and you can stay up later that might help. Failing that you'll need to head out a bit into the wilderness and hopef or a clear night![]()
How do you blend the photos? Are they overlayed using Multiple/Screen/etc. settings? I have tried a couple of layer settings, but either the images are too noisy or the number of stars are depleted...
Thanks Guys, and some amazing photos
Can you recommend a lens for my A65, i have £240 tops but less would be better... I should get some amazing photos if I manage to master this as i live on the Isle of Man, We have a small dam in the middle of a mountain that gives you perfect conditions when the sky is clear...
