The full version is paid for, but they do a free version allowing up to 20 users and 20 different build configurations so if you won't go over that it's worth looking at.
We use a bunch of Ant scripts, shelling out to stuff like JMeter. Didn't have the budget (i.e. any budget) for this kind of product. Shame really, it saves a lot of man hours.
Both offer timed builds with the option to notify via email on success/failure, as well as built-in support for metrics (NDepend, NCover) and unit tests (NUnit).
Been using CC.Net for ages, recently swapped to Hudson as it's much easier to configure, and has a Chuck Norris plugin.
We use Hudson, not personally used CruiseControl, but colleagues prefer Hudson. We also have the chuck norris plugin It's also easy to use an svn-hook so that builds are triggered when committed.
We've got a multitude of plugins installed, fxcop, stylecop, NDepend, NCover, blah blah..
