Nightmare with Logitech G29 on PC
Don
23 Oct 2005
North Yorkshire
Hi all,
I'm having an absolute mare getting G Hub to recognise my G29 steering wheel. I have just done about everything including reinstalling Windows!
On my Surface, it works fine, recognised instantly. On my PC, Windows will recognise it is getting plugged in, install the driver but G Hub cannot see it.
I read a reddit/YT guide on altering some things in the ghub program files to no avail.
It's driving me up the wall. Any ideas? It's a fresh install of Windows, I thought it might be the Logitech keyboard conflicting but again, plugging that into my Surface, all fine. Tried different USB ports etc.
Any ideas?
Anything else plugged in? My Xbox controller would always cause issues.
I thought maybe my Logitech keyboard being plugged in first could have conflicted with it so I reset the machine again. Unplugged everything. Only thing software wise is G Hub, same thing. It’s absolutely baffling
Unfortunately the software is rubbish. I had a similar problem on my G910. Eventually it resolved itself. Have you also installed the gaming software in addition to hub?
key thing is do not plug it in until asked. this is a key mistake many people make with logitech wheels.
so download software . install it will then prompt you to plug in the wheel.
from there is should be fine. some programs mess with logitech wheels like geoforce experience.
I tried every combo going.
In the end, I gave up, However, after plugging everything back in, low and behold G-Hub suddenly recognised it. I literally couldn't even own up to anything stupid I did, or help anyone with a future fix!
Cheers for the responses, alls well that ends well.
Yup, exactly what happened with my G910.
