Now that I like and I wish all cameras had it. Hopefully the next generation of Sony a7's will.Vloggers will get the Canon though because of the flip out screen to the side.
The white mark on the lens may be going from left to right, but you're still screwing anticlockwise even with the sensor facing away from you.
If you face a soft drink bottle towards you (the top of the cap is pointing at you), you fasten the top by turning clockwise or in this case left to right. If you turn the bottle 180 degrees, you still have to turn the top clockwise to tighten it. It's just going right to left now.
The Nikon lens turns anti clockwise no matter what way you're looking at it. A clock doesn't suddenly start going back in time because you face it away from you.![]()
Hahaha, this is just getting silly, who actually give a r4ts behind which way a lens screws on, I have only ever used Nikon, So my Nikon lenses screw on the right way, because its the only way I know, So what that all other lenses screw on the other way (they all all wrong btw, Only joking) lets leave this be, its a waste of everybody's time!
Apparently Raymond does, he is the one that brought it up. It is a waste of everyone's time and irrelevant
Well canon has just shown Nikon how to make a FF mirrorless camera and how to launch one
Canon EOS R specs and images:
30.3 Million Pixels Full Size CMOS
Dual pixel CMOS AF
The ranging range is 100 × width 88% of the live view video display range
EV-6 low brightness autofocus
4K video
Touch panel liquid crystal
Multifunction bar installed (2nd picture image)
Wi-Fi · Bluetooth installed
Dustproof drip-proof · magnesium body
Battery: LP-E6N
Battery grip: BG-E 22
Size: Width of about 136 mm × height of about 98 mm
Weight: Approximately 580 g
Mount: inner diameter 54 mm, flange back 20 mm, 12 pin
Mount adapter: “Mount adapter EF – EOS R” “Control ring mount adapter EF – EOS R” “Drop – in filter mount adapter EF – EOS R”
It will be launched with an adapter and the following FOUR new lens for the new mount
RF 35mm F1.8 Macro IS STM
RF 50mm F1.2L USM
RF 28-70mm F2L USM
RF 24-105mm F4L IS USM
That’s some tasty glass there which will make Canon users upgrade. Hopefully Sony will put their finger out and do a 35mmf1.8 now as well.
The 28-70 f2 will be great for wedding photographers.
Yeah, that is an enviable set of glass and knowing Canon it will be great quality. Lets hope that a good adapter is released to put RF glass on the FE mount... or otherwise Sonyy produces similar native FE glass to match.I must admit the new glass is a much better idea than Nikon efforts. If you are going to go with a new mount, adapters are fine but you need some good native and unique glass from the start.
Dual pixel CMOS AF
4K video
Battery: LP-E6N
RF 50mm F1.2L USM
RF 28-70mm F2L USM
Nope seen a real life picture of it and yes it is huge! Probably the same size as the sigma 105 f1.8
In which case the ergonomics must be horrible on such a camera. That kind of lens belongs in the 1D/5D4. Very unbalanced in weight, price and features. The Canon mirrored looks aimed at a lower level than The Nikon DZ, which itself is clearly marketed well below the pro level
Have you seen any actual word of this on any rumour site of this or are you just engaging in speculation that thy are "about" to launch a new pro mirrorless?But this is canons low end mirrorless body. Perhaps they are about to launch a $4000 more pro orientated body soon with dual cards, weatherproofing, IBIS etc?
Have you seen any actual word of this on any rumour site of this or are you just engaging in speculation that thy are "about" to launch a new pro mirrorless?![]()
Greebo, no-one in their right mind would think Canon are only releasing one mirrorless "ever" (lol), but I have also seen absolutely nothing to suggest they are "about" to release a new high-end pro mirrorless either.No but do you think Canonis just going to launch one relative low to mid specked mirrorless FF camera body ever? Same with Nikon when both are ploughing loads of money into new lens for the new mounts?
Hence why there may appear to be a mis match between the high end expensive pro f2 lens and a mediocre low body which won’t appeal to pro users. At least Nikon released both their bodies at the same time. Canon won’t intend to remain with just one low end body for very long. Perhaps it was meant to be launched already but they have last minute issues over IBIS or something, who knows
