Nikon 18-200/f3.5-5.6 G DX IF-ED
18 Apr 2004
London
Has any one got any comments on the Nikon 18-200/f3.5-5.6 G DX IF-ED I have been looking at getting a new lens to replace my Sigma 28-300mm F3.5-6.3 Macro (Not the DG one, the one before DG). My current lens is good however I find that at full extension unless in good light camera shake is bad so I was hoping that the VR on this might improve things, also the lens tends to be quite slow at focusing and makes a dreaful noise, so I think the Silent wave motor should improve this too, however the lens aperture's arent much of an improvement and I would be loosing 100mm. An opinons or what ever would be appreciated.
good look trying to get hold that 24 - 200 vr lens. your going to be waiting about 3 -4 months before delivery. I have been trying to get hold of one myself.
your best bet would be to look at the sigma 70 - 200 f2.8. nice lens apparently but without and image stablization.
Good luck.
King.
So as its in short supply that means its popular (or the factory blew up?) But this doesnt answer my question as to weather its a good lens, suitable as an alternative upgrade to my existing, also after reading further into it the retailers mention that it acts like a 28-300 on Nikon DSLR's due to the sensor size. If true it sounds even better!
Thanks
the 18-200 is an OK consumer lens, the only issues it has are distortion (par for the course in such a large zoom range),a bit of creep and slightly dubious build quality (not as good as the 18-70 kit lens as an indication.)
the 24-120 unfortunately isn't wonderful quality either, and it has the added problem that it isn't pin sharp and it's pretty slow compared to the 18-70.
bottom line is if you can live with the 18-200 build quality go for it, it's a good lens for the money and is pretty sharp.
really nikon don't have a mid range zoom with VR thats any good unfortunately, i wish they'd put VR in a 24-85 f2.8 or something....
EDIT: I assume you're using digital as this lens isn't for film (dx size sensors only). And yes, it's hard to get hold of because if you have a d50 or d70 it's a great travel lens or walkabout. (on a D200 it feels cheap)
