nikon d3200 movie issue
19 Feb 2012
received my d3200 today and when i go to select what movie qaulity i would like i should be able to do 1080p at both 24fps and 30fps
the problem is that i cannot get the 30fps and it is showing up as 25fps
i dont know if its my sd card as that is a sandisk extreme 32gb which i bought specifically for this camera as it does up to 45mb read and write which should be plenty. also my no name brand class 10 does the same thing, i would have thought the sandisk would be a lot faster?
i know an extra 6fps isnt going to make much if any difference to the camera but it would be nice to have the option its supposed to be with
any ideas?
I'm a Canon user, so not familiar with Nikon.
However, my suggestion for why you might not be able to select 30fps is perhaps because it needs to be set to NTSC in the camera settings. I've seen similar on other cameras.
If that's not the case, perhaps a Nikon user knows better.
awsome man!! it works now, changed it from pal to ntsc and now i get the full 30fps at 1080 and 60fps at 720
thank you!!
