Nikon D50 - Flash problem
Permabanned
20 Apr 2004
Far far away....
For some reason I can't get the inbuilt flash to fire on my D50. I can set the flash to fire in different ways but it doesn't actually flash.
Does any one have any ideas?
-RV- said:
What mode are you using ? Full auto, Portrait, Landscape, A, S, P, M ?
It doesn't fire in any mode.
Right now its on full auto mode and on the LCD display the flash is showing as Auto.
I'm in a dark room now with only the light from the street lamp out side, two monitors and a TV and it won't fire.
I have the exact same problem and i also have the D50. It wont flash no matter the settings.
Have you solved this issue yet?
Ive had a look through the menu and tried a few things but nothing works.
The flash pops up out of its compartment but doesnt flash.
The only thing i can think it could be is the other week i borrowed somebodys sb-600 flash gun and used it for a bit and i cant recall since then that it has worked.
Has anybody else had this problem?
Could this be a problem with all D50's?
Thank you
