I spent a long time thinking about the same camera. I went for the D3300 in the end and couldn't be happier. It was over a hundred pounds less, but ditches the wifi and swiveling screen, neither of which I needed or wanted anyway, and so makes the camera cheaper and lighter. Otherwise it's the same camera, more or less. Make sure you buy the Nikon 35mm f/1.8 prime lens, it's amazing and incredibly easy to use, try and get this in place of the kit zoom lens if you can, although that ain't a bad lens either.
