Nikon D80 Help...
14 Oct 2007
If I take a photo and the flash is ON, photo quality is PERFECT...If I take the flash off, image is blurry...How to I get the perfect photo WITHOUT the flash on?
In what conditions? Guessing a dark room? Your autofocus probably doesn't work properly in poor light so you can either keep the flash on but just use its autofocus assist light or manually focus on what you are aiming at instead.
