Struggling to find any information on Nikons underwater lenses... I've found a 15mm UW lens online that is relatively cheap and will cover me for a while while I save up for a 'proper' ultrawide, however I'm not sure what, if any, the differences are between normal and UW lenses, I've noticed some knobs on the outside of the lens, similar to Nikons tilt shift lenses, I'd also like to confirm that it would indeed work on a modern FX DSLR and will autofocus correctly above water (ok not a necessity, but would be an advantage).
