Caporegime
- 9 Nov 2009
- Planet Earth
Looks to be the new D600/D610,so is a half way house between the Z50 and Z6:
https://www.dpreview.com/news/60573...el-full-frame-camera-that-doesn-t-cut-corners
https://www.imaging-resource.com/PRODS/nikon-z5/nikon-z5A.HTM
Once the price evens out a bit,it looks a reasonable option,although the video is definitely a bit hit and miss.Nikon Z5 key features
- Entry-level full-frame mirrorless Z camera
- Affordable entry point to the Nikon Z system
- 24.3-megapixel full-frame CMOS image sensor
- Native ISO range of 100-51,200, expandable up to ISO 102,400
- EXPEED 6 image processor
- Shoots at up to 4.5 frames per second
- 5-axis in-body image stabilization promising up to 5 stops of stabilization
- Dual UHS-II SD card slots
- Weather-sealed camera body constructed using magnesium alloy
- 1,040K dot 3.2-inch tilting touchscreen
- 3.6M dot Quad VGA electronic viewfinder
- 4K/30p video recording (with crop)
- 1080/60p video recording (full frame)
- Built-in Wi-Fi and Bluetooth for Nikon SnapBridge compatibility
