Nildram connection speed issues
27 Jan 2005
Letchworth Herts uk
Hi All I want to get some feedback about an ISP ADSL Service ,i,m with Nildram on the 8meg contract , the highest connection that i get is 6.2 meg and thew lowest is 5.1 meg ,do anyone else get this ,or is this right ? I have been looking at changing my ISP and Zen seem to get my vote ,i know that they are higher in price,but i,d be willing to pay more if i got a higher conection rate ,is anyone on Zen's 8meg service, and do they get 8meg ? :confused:
Do you mean you are connected at 6.2mb, or are connected at 8mb and getting 6.2mb speeds? If you're connected at 6 then I doubt you'll get an increase by switching to another ISP as it's more to do with the line between you and your exchange (quality, distance) than your ISP.
I'm with Nildram and get the full 8mb, but I'm practically sat on my exchange.
yeah thats what i thought ,i,m about a mile from my exchange ,i,m connected 8meg and getting 6.2 ... :confused:
Could you post your SNR and Attenuation figures up? Your router/modem should be able to give you them. It'll give a good idea of what your lines like.
Where do i find that ?? :confused:
whats your router?
login to your router and check the options there, status, stats etc
but anyway if thats the max speed you can get, then changing ISP's will not help you, as its because of your phone line, not ISP
A2Z said:
whats your router?
thanks yeah i think its a phone line thing ,and in November we are going to be able to get the 24 meg service ,so will wait until then ;)
ruffneck said:
wouldn't get your hopes up of actually getting 24mb thou...
No i know ,but would get more than i do now ,which isn,t too bad from what i,ve been told .some only get 4meg on a 8 meg service ! :rolleyes:
