Nildram low pings
7 Apr 2004
Hi,
Im on Nildram Max, and my pings are generally very low
Code:
Pinging jolt.co.uk [82.133.85.65] with 32 bytes of data:
Reply from 82.133.85.65: bytes=32 time=203ms TTL=59
Reply from 82.133.85.65: bytes=32 time=402ms TTL=59
Reply from 82.133.85.65: bytes=32 time=418ms TTL=59
Reply from 82.133.85.65: bytes=32 time=411ms TTL=59
Ping statistics for 82.133.85.65:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 203ms, Maximum = 418ms, Average = 358ms
CSS games run at about 150ms, I noticed Interleaving is turned on if i ask them to turn this off will it decrease my pings at all? I was on about 20ms when i was with pipex.
Thanks
Jack
Yes, turning interleaving off will reduce pings.
However, the fact you are pinging 150-400ms indicates to me that your problem is much more than simply having interleaving enabled. Can you try the following:
-Disconnect all other machines on the network (if applicable)
-Make sure no applications are using bandwidth on your PC (especially uploads)
-Run a speedtest to see if the high latency is down to saturated bandwidth
-Try reconnecting your modem/router
Seems to be fixed now :)
Tracing route to jolt.co.uk [82.133.85.65]
over a maximum of 30 hops:
1 31 ms 32 ms 32 ms lo1-lon3-adsl21.nildram.net [195.112.5.30]
2 32 ms 30 ms 31 ms ge-1-1-1.cr2.gs1.bb.pipex.net [84.12.224.33]
3 31 ms 31 ms 30 ms lon1-9.nildram.net [84.12.224.14]
4 31 ms 30 ms 30 ms jolt-gw.nildram.net [195.149.20.214]
5 31 ms 33 ms 31 ms secure.jolt.co.uk [82.133.85.65]
Trace complete.
BeatMaster :D
tntcoder said:
Yep it does thanks for the tips guys, the pings are back down to 30ish, I may as well get interleaving turned off anyway i guess.
Did you ask for interleaving to be used on your line, or was it automatic?
I spoke to nildram to ask them if it was active on my line and the said they 'checked, but they didn't know?' I didn't really follow it up though.
Might have to now :)
SW.
