Hi,
Im on Max DSL with Nildram, and generally get 2.5mbit speeds. At the weekend we had some 'dogi power' i.e lights flickering and even a complete cut. I'm not sure if that was related but now my router is failing to sync correctly with a constantly changing downstream margin of between 0 and 4 db, when before it was locked at 6db i think (fully stable for the past 1.5 years anyway)
Current Stats:
This is obviously proving to be fairly unstable
Any ideas on how i can fix this? I tried powering off the router for 1 hour so it could clear/reset the profile? This however seems to have had no effect.
Thanks for any help
Jack
Current Stats:
Code:
DSL Modulation Mode: GDMT
DSL Path Mode: INTERLEAVED
Downstream Rate: 3808 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 1 db
Upstream Margin: 18 db
Downstream Line Attenuation: 57
Upstream Line Attenuation: 31
Any ideas on how i can fix this? I tried powering off the router for 1 hour so it could clear/reset the profile? This however seems to have had no effect.Thanks for any help
Jack
