I've had issues with the tap connector on the front of the nilfisk being cracked as soon as the first blast of water is released. The original cracked, then I replaced it and that cracked straight away too.
I have these connectors:
http://www.screwfix.com/p/brass-hose-fitting-set-4-pieces-4-pcs/13866
the metal connector has a water stop, which is what I have attempted to use.
Main question is, would the water stop function be causing this? Last time I used the pressure washer was last year, so I'm unsure what the problem may be. The only thing that has changed are the connections of the hose, i thought I would upgrade to brass from plastic, but this may have been a bad move?
