Ninja Bastille Disk IO
27 Sep 2005
London innit
At work we have some pretty unique use cases for hardware, we have some very very heavy IO related tasks so was just having a play around.
You can buy a Dell 2U server that will fit 12 * 2.5" SATA drives with a pretty decent RAID controller. Just pondering 12 * Crucial M4 512GB in RAID 6. Would make a very very nice DB server.
SSDs? Surely you'd want something else if you were going to constantly write - I know they've been getting better but I wouldn't want to put high writes on SSDs just incase you loose your RAID level and kill the array.
M.
M.
Heavy heavy read, it's like a 5tb memory cache :)
We probably have one of the largest render farms outside of ILM and Weta, probably the largest in Europe.
Sounds great! got some solutions like that at my place, but why oh why raid6 raid 10 is much faster in my experience, and by the sounds of it your writes are only important in the short term as its a caching device?
RAID6 is just as fast as 10 for reads, if anything it's quicker for the same size drive pool as you're striping over more spindles. It's writing latency where RAID5 and 6 fall over. But if you're writing once and reading many 6 is fine. Plus flash writes so fast and with such low latency you can get away with parity in places you traditionally couldn't.
