Ninja temps
Suspended
17 Mar 2006
What are people getting for idle/load with Scythe Ninja? Set my CPU back to stock and idling at 35 degrees c. Fully loaded 44 degrees Ambiant is 25 degrees.
Does this seem a bit high? :confused: Doesn't seem much better than stock heatpipe/fan, in fact I think similar or worse.
I'm getting 44 load in 20 degree room temp. Opty @ 1.42v.
Currently at 49 with fan on 5v and room temp 28.
haven't been that impressed with temps until i saw what others were getting with competing heatsinks.
I found making a duct to my rear case fan made a big difference.
Edit: Why is it idle? it should be folding.
Ive got mine on my P4. My room is very hot although i dont know the temperature :D
at 3.75ghz 1.43v idle = 35C and load = 47C
at 4.2ghz 1.48v idle = 37 and load = 51C
What are people getting now with this weather? Not too impressed with the Ninja tbh. Reduced CPU back to stock, 2.2ghz
40 degrees idle
27 degrees ambiant.
james.miller said:
well they're plain wrong. try 52c load on a 3ghz opteron 148 @ 1.55v.
fair shout on a 3ghz opty but some people are using mildly overclocked pentiums and x2 dual cores which is of putting as the ninja is supposed to be one of the best coolers
well my opty at 3ghz will put out enough heat, nobody else is having problems with ninja's. put it this way, my rise in cpu temps are right inline with the rise in my room temp - ~5c
