Right ive got a asus 680i board and im stuck as per usual on weather i should use the ninja or the tuniq tower... if i do use the ninja im thinking about mouning another fan on the other side of the unit creating a push pull method. Will this have any effect and will it mean that it will then be better at cooling than the tuniq
I think if I get to 3Ghz, that'll be where I'll stop
What's push-pull, etc? A fan arrangement? Push = blowing air into the case and Pull = sucking air out?
