Hi there
Here is yet more deals on certain selected lines, some are an absolute bargain especially the 9800 GT at £49.99+VAT, would be an ideal PhysX card.
XFX GeForce 9800 GT 512MB GDDR3 PCI-Express Graphics Card @ £58.74 inc VAT
The NVIDIA GeForce 9800 GT has arrived. Enjoy industry-leading features such as NVIDIA PhysX technology that brings your games to life and HybridPower for optimal power management. And with GeForce 9 Series goodness, 112 processor cores and a 256-bit frame buffer, this GPU’s got the stuff hardcore gamers have been waiting for.
- Core Clock: 550MHz
- Memory: 512MB GDDR3
- Memory Clock: 1800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 112
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 2.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Only £58.74 inc VAT.
ORDER NOW
XFX ATI Radeon HD 4890 1024MB GDDR5 PCI-Express Graphics Card @ £129.24 inc VAT
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance.
- ATI Radeon HD 4890 GPU @ 850MHz
- 1024MB GDDR5 Memory @ 3900MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
Only £129.24 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 12800C9 (1600MHz) Tri-Channel (CMX6GX3M3A1600C9) @ £126.89 inc VAT
The XMS Series CMX6GX3M3A1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £126.89 inc VAT.
ORDER NOW
OCZ Gold 6GB (3x2GB) DDR3 12800C8 (1600MHz) Tri-Channel (OCZ3G1600LV6GK) @ £123.36 inc VAT
The OCZ PC3-12800 triple-channel memory kit designed specifically for the impending Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 3GB and 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Only £123.36 inc VAT.
ORDER NOW
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 12800C6 (1600MHz) Dual-Channel (OCZ3RPR1600C6LV4GK) @ £82.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements and tight CL6 timings at 1600MHz.
Developed for speed-hungry enthusiasts and gamers with overclocking on the mind, these new OCZ modules were engineered with the same performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for desktops.
OCZ DDR3 PC3-12800 Reaper Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety Reaper HPC Heatsink for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 6-8-6-24 (CAS-TRCD-TRP-TRAS)
- Available in 4GB optimized kits
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
Only £82.99 inc VAT.
ORDER NOW
Palit GeForce GTX 460 Sonic Platinum 1024MB GDDR5 PCI-Express Graphics Card @ £211.49 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 800MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Processing Cores: 336
- Shader Clock: 1600MHz
- Display Connectors: 1x VGA, 2x Dual-Link DVI-I & 1x HDMI 1.4a
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Only £211.49 inc VAT.
ORDER NOW
HP Compaq Mini 311c Intel Atom N270 1.6GHz ION 11.6" Netbook - XP Home (VJ555EA#ABU) @ £246.99 inc VAT
The Compaq Mini 311 is a digital companion with enhanced graphics and HD capabilities for fun multimedia enjoyment in a functional mini format. Enjoy an 11.6" screen, Windows XP Home and NVIDIA ION graphics for smooth HD playback. The Compaq Mini 311 has a 92% full-size keyboard so you can use email and IM as they were intended. VGA and HDMI ports allow fast connection to your TV or monitor for sharing. WLAN connectivity allows you to stay in touch with friends via social networking sites or IM using the built in Compaq mini webcam. The built-in microphone guarantees crisp, clear online conversations. When you get home, plug your Compaq Mini 311 into your main PC and let Syncables do the rest! Update your files, bookmarks, emails, and more in just a click.
- Operating System: Microsoft Windows XP Home 32-Bit
- Processor: Intel Atom N270 1.60GHz
- Graphics: NVIDIA ION
- Memory: 1GB DDR3 RAM
- Hard Drive: 160GB
- Screen: 11.6" HD BrightView LED Display (1366x768)
- Bluetooth: Bluetooth 2.0 + Enhanced Data Rate
- Wireless LAN: 802.11b & 802.11g
- Ethernet LAN: 10/100
- Sound Controller: High Definition Audio
- Speakers: Altec Lansing Stereo
- Card Reader: SD Card, Memory Stick, Memory Stick Pro, MultiMedia Card, MultiMedia Card Plus & xD-Picture Card
- Camera: Webcam (Integrated Microphone)
- Security: Kensington Lock Slot
- Connections: 3x USB 2.0, 1x HDMI, 1x VGA, 1x RJ-45 & 1x Speakers/Headphones/Microphone
- Battery: 6-Cell Lithium-Ion
- Dimensions: 289.0mm x 204mm x 30.6mm
- Weight: 1.46kg
- Warranty: 1 Year
Only £246.99 inc VAT.
ORDER NOW
The 9800 GT and 4890 are very strong deals.
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
ORDER NOW
- Shader Model 4.1
- On-chip HDCP
ORDER NOW
- Lifetime Warranty
ORDER NOW
- 1600MHz DDR3
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
ORDER NOW
- 1600MHz DDR3
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
ORDER NOW
- Hard Drive: 160GB
- Weight: 1.46kg
- Warranty: 1 Year
ORDER NOW
