Nissin Air Commander for Fuji
16 Sep 2005
What used to be a UK
Does any one know if you are able to mix and match different versions of Nissin air flashes that are air remote compatible and which would be the cheapest to use as a second flash in conjunction with the i60a?
Yes you can mix and match other Nissin flashes, and you can even use third party flashes so long as they have the Receiver Air R attached. So, you could for example use an i40 or Di700A as your second Nissin flash ( personally I use multiple i60A strobes when using my X-T2 though ).
