- 31 Jan 2012
Hi all
Having bad neck/back problems is turning the search for a home office chair into a nightmare
I'm not exactly tall but I need a high seated chair as along with gaming and normal use I need to reach around a couple of large desks with lots of music gear and keyboards scattered across.
I've been looking at both high seated ergonimic office and gaming chairs but the seat height is often stated differently across websites when shopping around.
Im ideally looking for something above 600mm and was originally set on the Dynamo Onyx Ergonomic Posture Chair with Headrest. But when looking even this has varied seat heights from 580mm to 640mm, its also pretty pricey.
Then I found the Nitro 300EX Gaming Chair which says on OC and other reviews it has a max seat height of 61cm but Ive now seen a couple of comments saying the seat height was actually 55cm?
I also really liked the Noblechairs Icon but at 58cm, while it would probably be sufficient, Id like the option to go higher if needed.
So sorry to ramble but can anyone confirm the maximum seat height of a Nitro 300?
Are they comfortable? Especially if you have neck and back issues?
Or are there any other highly reccomended high seated ergo chairs?
Thanks
Thanks
