I have an RX 480 Nitro+, at stock, factory overclock (1342MHz/2000Mhz).
I've noticed that the core clock in 3DMark (none of the tests seem to matter, be it Firestrike, TimeSpy etc) is throttling and never peaking to 1342, it'll instead hover around 1280-1300, with the GPU load at 100%.
This only seems to be happening in 3DMark, where as I can run Heaven and Valley for hours on end and it won't budge, it'll stay locked on 1342.
I'm also using an aggressive fan curve to keep it under 70c, so GPU temperature isn't going any higher than that, so it can't be thermal throttling, right?
