nLite Driver help, Please.
20 May 2006
I'm trying to install Windows on a drive that's pluged into a raid controller.
When using nlite to put the drivers into the XP disk, what option should i select?
PnP or Textmode?
I've made 3 disks and none of them have worked >.>
you are keeping the txtsetup.oem file in the default place yeah?
extract the files from the zip file to a folder as they appear in the zip.
if you're having more problems with it, register and ask on msfn forums, nlite has it's own section, you could also ask this guy to add rocketraid drivers to his pack (he's added every driver i've asked for) http://www.msfn.org/board/RAID_Slipstreamer_t85842.html
