- 4 Dec 2008
As usual, nLite's managed to **** up in some way, this time trying to integrate my whole C:\ drive
I have the .ini files it makes that you can preload, but when I run it on my install files it says that it's detected an incomplete nLite operation and to replace them with clean files.
They are, however, clean new files, pulled right off the disk.
Any ideas how to get round this?
Cheers
EDIT: nvm, turned out it had modified my source files too ¬¬ finally got it working right.
I have the .ini files it makes that you can preload, but when I run it on my install files it says that it's detected an incomplete nLite operation and to replace them with clean files.They are, however, clean new files, pulled right off the disk.
Cheers
