nlite issues - advise
5 Jun 2005
Southampton
hey guys, i have a generic win xp nlite build which i use for certain laptops i repair, used it on a friends pc rebuild, all fine accept i have a default 'admin' logon built in which is fine, windows will bootup and login however i deleted that account and created a user name one, when xp boots it gives me an error saying cant find admin account. anyway i can strip that out? and stop it from happening.
Can you login to the other user?
If so run 'control userpasswords2' at the run window. Then just change the user that automatically logs in!
yeah everything works fine it just tried to login to account that does not exist anymore that i deleted and don't want. the other accounts work fine
Try the 'control userpasswords2'. Using that you can set it to ask for a user to login as, or set the default that it will login as. Which currently is Admin, but you can change it!
