Nlite question
seperatly
if you know exactly which driver it is, and have it handy use nlite
or if you want a shotgun approach, use this tool, then use nlite to build the disc again..
http://www.msfn.org/board/RAID-Slipstreamer-x86-x64-t85842.html
The SATA drivers that were already there will still be there unless you explicitly remove them. The ones you'll add will be in addition to what's existing.
sorry misread a bit, i thought you were slipping sp2 into disc and asking if you need to do drivers too.
sp2 has some drivers, but far from all
if you add them using tools above, then you'll never have to F6 or use a floppy
