nneed dongle tips/help
7 Nov 2009
hey guys my dad uses a dongle to connect to the internet, he cannot sign up for broadband because he has problems with his bank so he needs to use a top up service to connect to the net.
he currently uses the 3 network and it isnt the best, during bad weather he finds problems connecting, its a very unstable connection.
Is there any tips i can give him or a good website that will tell you the best dongle to use for that area? or are there any downloadable apps that will help keep it stable?
or even an alternative to a dongle? cheers!
If you set the APN to 3internet.ie instead of just 3internet, I have been getting full 2 - 3 meg connection speeds ( on downloads / and off peak ) and streaming / browsing works well at anytime .... xbl works pretty good as well.
In the case of bad weather, there is not a lot you can do except in my case I have used a usb extension cable and placed it in the window to try and give the signal less obstructions to pass through.
