No 4GB 2000MHz DDR3 on OCUK?
27 Aug 2007
Surrey
I'm looking for some OCZ or Corsair 2000MHz DDR3 2x 2GB (4GB), however, can't find the stuff anywhere, even though it's available from the manufacturer? :confused:
Also, in order to obtain 2000MHz I know I'll need a 500MHz FSB, but would that not only give me 1000MHz DDR? Or will I have to use a memory divider with the Asus Striker II Extreme? Sorry if that's a dumb question, however, never built an Intel rig before and currently am still using DDR400.
I could get 2x 2GB of OCZ, however, will it work at published latencies at 2000MHz??
Bugger... just been reading the forums over @ OCZ, apparently, it's unlikely I'll even be able to run 1600MHz+ without disabling 2 of the 4 cores when using a QX9650/Asus Striker II Extreme combo and 4GB OCZ RAM... WTF?
http://www.ocztechnologyforum.com/fo...ad.php?t=37758
OCZ actually recommend a dual-core CPU (E8500 for example) for 1600MHz+ for my planned mobo & RAM!
I'm rapidly changing my mind again... DDR2?? :confused:
