No analog brake option in TrackMania:United Forever
Caporegime
27 Nov 2005
Guernsey
This is a bit strange and annoying..
You can choose analog accelerate and steering..
But there no analog brake :confused::(
yeh iirc I think it expects you to use a combined axis, e.g. on a 360 pad the two triggers are only one axis where the resting position is in the middle of the axis, press left trigger and it goes to minimum = brake, right trigger goes to maximum = accel.
Is a bit annoying because tapping the brake stops the car rotating in the air in trackmania but it doesn't work with analog controls...
Thanks..am going test it now ...
Think the brake button also makes the car go backwards if i remember right..
I tried using my 360 pad but I'm a lot faster when using keys, although I mainly play stadium, not really into the other modes.
