- 9 Jun 2007
Ok, now started to install my new system, after being away in Europe for some time.
Installed XP Pro on the new HDD and then installed the MoBo drivers from the CD Rom using the Express Install.
Rebooted the computer, and found that my Audio is not working.
I am using the Rear Audio channels and not the front ones.
Even though I installed the drivers from the CD Rom installation, the device manager states that no driver exists for my High Definition Audio Bus.
But my System Device shows that the Microsoft UAA Bus Driver is working properly.
I have reinstalled XP 3 times now and manually installed the HD Audio Drivers in different sequence and still no audio.
I have even downloaded the latest audio Drivers off the Gigabyte site and I get a error message when I try and install that.
I also get an error message when I try to uninstall the drivers because it says that no driver exists.
Done a few searches on the net for this, and it seems a common problem, but no solution.
Does anybody here have one, as I assume that a lot of you have this board, or have you purchased an extra sound card ?
Lee
Lee
