No audio on WMP
19 Jan 2005
Romford, Essex
I haven't used it for ages and now find that I have no audio. My Maudio card is working OK for Foobar, Spotify and iTunes but not WMP.
I tried a rollback to WMP 9 instead of 11 and it makes no difference.
If I go into WMP / Tools / Options / Devices / Speakers / Properties / Delta 1/2 (my card) properties / Advanced and the whole page is blank and unable to select. Maybe that's right I don't know but I cannot find anywhere else that is connected to WMP to check.
Although I don't use WMP at the moment I want to make sure it works to check DVD rips.
Help please to get the sound enabled. Cheers.
BTW I run XP Home. The card is Maudio 24/96 which I know (I think) worked OK in WMP.
