Well, it appears my Z4's lost its blow.. thing is I've never had to have it on and only tried it today out of novelty.. but to my dismay its a no go into the cabin.
No matter if its air con, recycled air, warm, cold, max chill.. doesnt matter.. you get a faint whisper out of the passenger side vent. The others are barely noticeable without using your cheek up against it. The centre vents give off a nice whistle at max with the twiddlers open fully, but still no blow.
Fan can be on full whack and you can hear it loud, its working behind the scenes. Took a look under the hood but I can't see anything wrong per se. No loose hoses, compressor seems to be OK.. but this isn't really an air con issue. The issue appears to be something is stopping air getting into the cabin completely.
Are there any common issues or Z4 specific ones I should be looking out for? I've done my fair share of Googling, but just coming up with people's air con issues and mine isn't a cold air issue.. max temp.. it still doesnt blow. It just gives some residual heat passing up from the matrix, I imagine.
I'm just going to go de-construct the glove-box to take a look at the filter and see if that's blocked... but tomorrow it's a phonecall to the place that serviced it about a month ago.. and then probably a phone call to my nearest dealer.
Any other ideas / hints / tips / free sex / business ideas are much appreciated.
