No boot device error
20 Oct 2002
North West
So I’ve just started getting the No boot device please insert boot device” error. I’ve done the usual steps (yesterday the disk was healthy in Samsung magician).
- used diskpart, can’t do a fixboot as I get access denied. Done the steps do format the EFI partition but still get aces a denied.
- Disk is online and shoes as healthy in diskpart
- windows repair wouldn’t work
- just had the cmos battery out, still no joy
- going to try a format now
is this ever a case of just a dead drive? I’ll see how a format goes.
Have you tried doing it outside of Windows ? the drive could be in a frozen / locked state, if I remember right the Samsung Magician software comes with a secure erase utility that goes onto a USB stick then you just boot from that instead.
I offlined the drive and brought it back...no dice. Formatting seems to have worked for now. We will see.
Well, slightly concerned it’s underlying issue - seems ok at the moment
Had this once with a Crucial SSD on a Gigabyte AM3 motherboard with an FX8350.
Built, installed Windows, was fine for a while.
One day no boot device, ended up reinstalling Windows, was fine for a while again.
Did this several times. Turned out that drive just didn't like that board. I updated the firmware, didn't help.
Swapped the SSD with another machine, never happened again. SSD still working now.
