Man of Honour
- 14 Aug 2005
- York
I need help quick i loaded xp and my pc just keeps restarting before xp loads it just says Low Virtual memory then reboots... how do i solve this i cant get into xp to change the paging file please help thanks
unplug all the drives except the one windows is on. if it boots, right click my computer, properties, advanced, performance>settings, advanced tab, virtual memory>change. from there select "system managed". now shutdown the pc cleanly. re-connect the new drives and try again.
