Friend went away for 5 weeks, came back home and plugged his PC in and pressed the powerbutton and nothing happens.
The LED on the motherboard lights up green no problems - no PC speaker hooked up so no beep codes. But nothing fires up, the PSU, none of the fans - pressing the button does nothing. He did say that there was a slight burnt smell when he tried to turn it on, but like dust burning like when you've not used your toaster for a while. When that happened, the symptoms were the same - nothing span up, no fans or anything.
Sadly it's an AM2 board and I've got nowt to test it with. Tried removing all the ram and turn it on to see if it complained or anything, but niente. Also the wizard who installed the motherboard used a mix of screws and plastic plugs so I can't remove the motherboard without sacrificing a goat or something first.
Any ideas? Tempted to think dead PSU as it looks to be a cheapy one. Sadly no spares to test with.
