Just build my 1st water cooling loop and cannot get it to circulate, I have positioned the case in every orientation, shaken it around and have got 3 quaters of a litre of coolant in it by filling the res, cycling the pump and filling from the top rad also but no circulation still.
240mm x 60mm rad in roof
240mm x 30mm rad on front panel
phobya uc1 cpu waterblock
EK r9 290x water block
EK dcp 4.0 pump
10 cm cylinder res
res - pump - cpu - top rad - gpu - front rad - res
any suggestions ?
EK dcp 4.0 pump
10 cm cylinder res
any suggestions ?
