Hi all,
Just put some powerline adapters in my network, getting a nice 290mbps on the status indicator utility. Doing a ping to my router from here is good;
As you can see from the above [Non spoiler] the pings are fine other than the occasional higher spike. No dropouts, but i get the "No data received" within Chrome.
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=11ms TTL=64
Reply from 192.168.1.254: bytes=32 time=7ms TTL=64
Reply from 192.168.1.254: bytes=32 time=21ms TTL=64
Reply from 192.168.1.254: bytes=32 time=8ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=9ms TTL=64
Reply from 192.168.1.254: bytes=32 time=6ms TTL=64
Reply from 192.168.1.254: bytes=32 time=15ms TTL=64
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Reply from 192.168.1.254: bytes=32 time=17ms TTL=64
Reply from 192.168.1.254: bytes=32 time=14ms TTL=64
Reply from 192.168.1.254: bytes=32 time=12ms TTL=64
Reply from 192.168.1.254: bytes=32 time=13ms TTL=64
Reply from 192.168.1.254: bytes=32 time=18ms TTL=64
Reply from 192.168.1.254: bytes=32 time=10ms TTL=64
Reply from 192.168.1.254: bytes=32 time=16ms TTL=64
