- 1 Nov 2010
Hi,
I had a problem with my EVGA 980ti Hybrid, I sent off to EVGA and got a replacement back this week.
The problem is that if I let my PC boot normally then after the BIOS it says no display.
If I enter the BIOS and either exit without saving or force the boot mode then everything loads fine and the cards works perfectly.
I've unistalled and reinstalled the GPU driver with the laters whql driver but still no luck.
I've also tried setting the primary display in the bios to PCIE and this has no effect. When setting this to iGPU and connecting to the MB output windows loads fine.
I'm using Windows 10 home
MB is an Asus Maximus Gene V with a 3570k.
I have two monitors connected primary on display port and secondary on Dual Link DVI-I.
Anyone have any ideas?
